How to learning using Celonis
  • Oct 27, 2024 12:11 PM UTC
  • 312 views
tomnguyen
Level 2
Hello everyone, I am an employee from a technology company called Terus. I am assigned to learn and know how to use Celonis, then bring it back to apply to the company's process, but I currently do not have a clear plan for this move because in my country, not many people use Celonis.
By chance, when I was researching, I noticed that this community and everyone shared a lot of information related to Celonis. I want to ask about the roadmap that everyone learned to use and apply Celonis? I hope everyone can give me an answer!
Best answer by andré.tafur
Hi tomnguyen,
You should start using Celonis Academy (hyperlink here)
There you will learn from methodology to usage of the platform.You will also find specific training tracks for different roles within your organization.
Hope this helps.
Regards.
andré.tafur
Level 8
Forum|alt.badge.img+19
  • Level 8
  • Answer
  • Oct 28, 2024 2:19 AM UTC
Hi tomnguyen,
Hope this helps.
Regards.
tomnguyen
Level 2
  • Level 2
  • Oct 28, 2024 10:37 AM UTC
Thank you my friend
