How to integrate Ticket Management System (e.g, BMC) in Celonis?
  • Jul 26, 2023 8:55 AM UTC
  • 85 views
ravirajgouda.patil
Level 0
How to integrate Ticket Management System (BMC) in Celonis?  Once it detects abnormalities/anomalies in the defined process
  • Jul 27, 2023 12:14 PM UTC
Do you mean upstream integration or downstream? If it is downstream, lets use AF
It seems Celonis doesn't have a built in integration from AF to BME (at least, I couldn't find) but I am pretty sure using API calls you should be able to open a ticket in BMC (besides, most ticketing systems support opening tickets from mail, slack, etc...)
HTH
