How to install R package tidyverse in a script on ML Workbench?Thanks for your answers in advance.With kind regards Christoph
  • Mar 6, 2023 8:03 AM UTC
  • 127 views
Hello all,
is there a way to install the R package tidyvers in the ML Workbench. I have tried two possibilities which unfortunately run into an error (see screenshots).
With kind regards
Christoph
In R on ML WorkbenchScreenshot
In Py on ML Workbench
Hi Christoph,
Thank you for sharing the details of the steps you have already tried.
Please note, tidyverse is pre installed on all workbenches. Can you double check if you have opened the R notebook?
The following command can be used to list the installed packages. Can you check if tidyverse is in the list by you too?
installed.packages()
If that doesn’t work can you either:
  • Upgrade the workbench if it is not on the latest version
  • Install tidyverse manually with conda: conda install r-tidyverse
I hope this will helps to continue working on your project.
Best regards
Levente Harmos
  • Mar 10, 2023 1:08 PM UTC
Hi Christoph,
Best regards
Levente Harmos
Hello Levente, it seems that all R packages are now installed. Thanks a lot for your help and have a nice weekend. Best regards Christoph
