How to implement conformance checker with own process flow
  • Jun 22, 2022 1:04 PM UTC
  • 189 views
We have lack of knowladge . We would like to load a process flow like this.
Lets assume we have process Flow like that A-> B-> B->C-B->B-> D->B->B->E
When we do conformance I would like to use A->ANY To ANY -> C Any to Any ->D Any to Any->E
I mean Any activity between A->C could be exits.
We tried this solution but unfortunately, it didn't work as expected. All of our cases detact as violation. We implement BPMN as below. What we did worng ?
Vahide.
  • Jun 23, 2022 8:52 AM UTC
Hello Vahide,
According to your example process, it looks that we need to use "Exclusive" gateway instead of "Event" gateway.
If the above solution also does not work, I would recommend generating process model from actual process flows which satisfy your conformance condition.
Regards,
HT
  • Jun 28, 2022 7:41 AM UTC
Hello Hayamu,
We maintain BPML as below (yellow marked are mandatory steps in flow).
But it didn't work as we expected. Did I made someting wrong ?
image.pngBest Regards,
Vahide.
