How to identify a variants have duplicated activity?
  • Sep 6, 2023 9:12 AM UTC
  • 139 views
Hi all expert,
I would like to identify all case if it has duplicated continuous activity.
This is example of my case below.
...A -> A -> B ...(duplicate)
...A -> B -> A... (non-duplicate)
Does anybody know good PQL or way how to do this?
Best answer by Anonymous
I would use the Lead statement for this:
sum(
Case
when LEAD ( Activitytable.activitycolumn , ORDER BY ( activitytable.timestamp) )
= Activitytable.activitycolumn
then 1.0
else 0.0
end
Each case that has 1 or more, has duplicate activities.
  • Answer
  • Sep 6, 2023 11:12 AM UTC
sum(
Case
then 1.0
else 0.0
end
  • Sep 7, 2023 7:04 AM UTC
sum(
Case
then 1.0
else 0.0
end
Thank you for your response. Just to make sure, by using the Lead function, does this formula refer to the next Activity name that is ordered by to determine if they are the same or not?
