How to hide null values from a pie chart?
  • Mar 11, 2022 3:33 PM UTC
  • 75 views
I have this pie chart and was wondering if there's a way to hide null values? (the grey area)
thanks,
terence
You can use filter on component, sheet or whole analysis to exclude those values.
In case it should only in the pie chart, you need to activate edit mode, edit the chart, go into "component filter" and use below statement where "Table_Name"."Field_Name" is replaced by values used as dimention of the chart.
obraz
@1460074487 Let me know if that work :)
Mateusz Dudek
