How to get, within the same data pool, tables from one scope to another?
  • Sep 15, 2023 9:54 AM UTC
  • 193 views
We have an extractor set-up, but had to manually input a table. Now, we can't call such table in the extractor's data connection schema because it is in a different scope (manual uploads require a global connection, hence the different scope ).
dennis.pflug
you could write a transformation in Global Scope that is creating your table in different scope namespace.
E.g you have a table <YOUR_TABLE> in global scope.
You can use:
CREATE TABLE <%=DATASOURCE:YOUR_SCOPE%>."YOUR_TABLE" AS
(SELECT * FROM YOUR_TABLE);
  • Sep 15, 2023 2:55 PM UTC
You can use:
Thank you so much for replying!
I'm getting the error message "Execution error: Not allowed to access schema DATASOURCE:ABC_Extractor". Any idea on how to circumvent this?
muthappan.alaga
Level 8
i dont think you can call a table in Global schema from another scope(Target Scope). Instead create a view or table in the Target SCOPE by using this table in Global schema.
Forum|alt.badge.img+28
@muthappan.alaga is right, only the global scope can 'see' data from other scopes. It should be possible however to create new tables in other scopes in a Global Transformation, as explained here: How do I copy a table from one Data Connection to another? (celonis.com).
Next to that, during a manual upload, you should be able to specify the target scope, so you can upload it directly to the right place. See the 'Configure Upload' options as specified here: Uploading files (celonis.com)
