How to get time intervals by adding 30,60,90 days to EVENTIME, as when tried it always picks 30 days with case when statement. any suggestion would be great help.
  • Jan 20, 2022 6:06 PM UTC
  • 66 views
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Jan 21, 2022 12:36 PM UTC
Hi @1460069841 ,
If I understand correctly you would like to aggregate the time difference between two occurrences to 0-30, 31-60, 61-90, 90+?
The reason why it only returns 30 days is because in essence you're doing this:
WHEN DAYS_BETWEEN(date1, date1+30) < 31 THEN '0-30'
where DATE1 is youre PU_FIRST thingy :)
This is by default always true. So I guess you need to change either one of the date fields.
Second, I do not understand why you add 30 days to a date, to then check the difference. Would'nt it be easier to not add the days?
Hope this helps!
