how to find number of duplicate invoices in AP process
  • Dec 22, 2021 5:37 AM UTC
  • 112 views
Forum|alt.badge.img+13
Hi Can someone please help with PQL script to calculate duplicate invoices
  • Celonaut
  • Jan 19, 2022 1:24 PM UTC
I would suggest to take a look at the Duplicate Checker.
There is an App in the EMS Store called Duplicate Invoices where it is possible to leverage Celonis Duplicate Checker, purpose-built to ensure duplicate payments get prevented.
At a glance, the following figures are presented:
  • Duplicate Value (open): Indicates the total value of potential duplicates discovered by the ML-Sensor
  • # Duplicates (open): Indicates the number of duplicate pairs discovered by the ML-sensor
  • Duplicate Value (valid): Indicates the value of confirmed duplicates by the AP clerk
  • # Duplicates (valid): Indicates the number of duplicate pairs confirmed by the AP clerk
Please find attached a pdf that provides guidance for its usage as well.
Kindest regards,
  • Level 2
  • Feb 18, 2022 9:36 AM UTC
