How to filter output from MATCH_PROCESS_REGEX(some statement). All the results with value=1 is expected. I am using CASE WHEN (MATCH_PROCESS_REGEX(some statement) = 1) THEN 'A' else 'B' END;However, it is not working. (error attached)Pls suggest
  • Apr 12, 2022 5:38 PM UTC
  • 27 views
Error_screenshot
  • Level 5
  • Apr 13, 2022 6:17 AM UTC
Hi @1460063993 ,
Try using this code. Hope it helps.. I have added the LIKE functionality
MATCH_PROCESS_REGEX ("_CEL_C2R_ACTIVITIES"."ACTIVITY_EN", LIKE '%Set Status to On Hold%')
Hope this helps as I feel that your statement is not able to find that activity and hence returning zero.
Regards,
JayB
