How to filter an olap table to only show positive results os a difference between columns(explanation bellow)
  • May 26, 2023 9:36 AM UTC
  • 95 views
Hello all, im trying to compare the sales between last week and the weekly average of the last 6 weeks in several materials. For this I wrote the following code for the kpi:
(material is set as dimension)
(there is a component filter that limits the data to the last 6 weeks as well)
round ( ( ( 7 * SUM ( "VBAP"."NTGEW" ) / 43 ) / 1000 ) - ( ( SUM ( Case When "VBAP"."ERDAT" > ADD_DAYS ( TODAY ( ) , - 9 ) THEN "VBAP"."NTGEW" else 0 end ) ) / 1000 ) , 2)
However, in the OLAP I only want to see the materials where this difference is positive so I tried to do a filter where:
FILTER "Material" IN (CASE WHEN "DIfference code above" > 0 THEN MATERIAL ELSE NULL END)
But I get an error message saying that I cannot use the SUM aggregator in Filter.
Does anyone know how to solve this ?
  • May 26, 2023 11:31 AM UTC
I think you need to use a PU_SUM instead the SUM.
Without digging too much in your PQL, I guess it should work with PU_SUM(CONSTANT(),your case when stuff...)
HTH
