how to extract data from file which is uploaded from file upload folder and create a data connection in data pool in celonis studio.
  • Jun 14, 2022 6:19 AM UTC
  • 133 views
  • Jun 14, 2022 1:12 PM UTC
Hi Nikhil ,
Once you upload the file using the "File Upload" option .. and if the upload is successful , it automatically creates a table .
Sometimes you may find the newly created table under Global Schema.
The name of the table is decided based on the datafile name you are uploading.
Please mark this as best answer if my response is helpful to you!
Regards
Ayan
