How to delete trigger subscribers?
  • Sep 20, 2024 9:38 AM UTC
  • 139 views
astha.j
Level 3
I have a trigger which is link to 2 subscribers. I'm not able to delete the subscribers, so when I delete the trigger, it gives following error.
You may need to navigate to the Webhook page first and select the respective webhook from there. You can find that page by clicking on "Studio" (the overview with all packages) and then selecting "Automations" in the top right corner. Hope that helps!
Valerie
