How to create Sheet level date filter using a dropdown?
  • Apr 8, 2022 8:14 AM UTC
  • 57 views
I have to create a date filter (which should be a dropdown), that only filter the components in that particular sheet. I think this can be done using a sheet filter by setting a variable using a button dropdown. The problem is that the date is in DateTime format, and it writes to the variable like this : "Sun Jan 03 2016 05:30:00 GMT+0530 (India Standard Time)", I am new to pql and I don't know how to convert it into a proper format so that it can be used with FILTER statement in load script. Please help me out.
  • Level 5
  • Apr 13, 2022 7:22 AM UTC
Hi @mohammad.nomaan.husai ,
Try using the below filter statement. It will work..
FILTER "_CEL_INC_ACTIVITIES"."_CEL_CHANGE_DATE" >= {d '2022-04-13 00:52:04' }
Syntax is FILTER Table.DateField Operator {d 'YYYY-MM-DD HH:MM:SS}
Regards,
JayB
