How to create a dimension switcher?
  • Jun 30, 2024 4:30 PM UTC
  • 130 views
julia.bauer
Level 9
Hello everyone,
I want to create a dimension switcher within a view (s. example from a Celonis App). In the installed APP, however, I cannot access the originial knowledge model as the one visible is an extension. Hence, I do not know how the configuration of a dimension switcher is done on the YAML knowledge model side.
Does anyone have a step by step explanation?
Thank you!
Best regards
Julia Bauer image
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
Can you give us a screenshot of a element configuration options? It's a old view or a new one?
Mateusz Dudek
julia.bauer
Level 9
  • Level 9
  • Jul 15, 2024 9:46 AM UTC
Hello @Mateusz Dudek ,
it is an old view. The dimension should either display the count of purchasers or the count of activities (of a certain activity). Since the number of purchasers is barely to be seen due to the scaling of the chart, I wanted to add a dimension/KPI switcher to switch from the activities to the number of purchasers.
Thanks for your help!
Best regards
Julia Bauer image
