How to convert a string to a datetime format with milli seconds?
  • Feb 15, 2023 12:29 PM UTC
  • 6 replies
  • 174 views
I would like to convert a string to a datetime format with the following formula:
TO_DATE('2018-01-03 00:00:00.', FORMAT('%Y-%m-%d %H:%M:%S'))
However, this is limited to accepting seconds as the finest gradient of formating according to the documentation. Is anyone aware of a %... Identifier for milliseconds?
A workaround that works for me is:
ADD_MILLIS ( TO_DATE('2018-01-03 00:00:00.', FORMAT('%Y-%m-%d %H:%M:%S')), 100)
Though being a lot less elegant and I would have to split a column into its milliseconds and subsequently join them again. A native solution would be the preferred option.
Kind Regards,
Maurits
Forum|alt.badge.img+28
Hi Maurits,
As far as I know, this doesn't exists in Celonis. You can maybe simplify the formula by using LEFT and RIGHT, to take the first and last characters respectively.
ADD_MILLIS ( {t LEFT("Table1"."Column1" , 18)}, RIGHT("Table1"."Column1" , 3))
  • Feb 15, 2023 2:16 PM UTC
Hey Jan,
Yeah that's what I thought. Unfortunate.
Thanks for the cleaner code!
carlos.taleg11
Level 9
Forum|alt.badge.img+10
I use this mask to get milliseconds:
TO_TIMESTAMP(BUIN_TI_START_INTERAC, 'YYYY-MM-DD HH:MI:SS.MS')
Greetings,
Carlos
  • Feb 17, 2023 8:26 AM UTC
Hey Carlos,
Thanks, that mask works.
Though it's a depreciated function, so Celonis should integrate Milliseconds in their to date formatting. I'll make sure to post a feature request.
Kind Regards,
Maurits
  • Jul 28, 2023 1:56 PM UTC
Hey Carlos,
Kind Regards,
Maurits
Hey @1460069522 did this ever come to anything? Can Celonis handle miliseconds?
  • Jul 31, 2023 8:00 AM UTC
@gerald.dunn unfortunately, never heard back. The depreciated function should still work I think.
