How to connect Smartsheets with Celonis?
  • Dec 8, 2022 8:35 AM UTC
  • 6 replies
  • 97 views
Hello together, i am trying to connect Smartsheet with Celonis. I already have a Client ID and Client Secret for Smartsheet but everytime I try to connect both, Celonis/Smartsheets opens a new tab showing an error saying Redirect URI ist missing or wrong. Does anyone know what to fill out in the Developer Settings of Smartsheets in the field APP URL & APP redirect URL ?
I have filled in an APP URL (something like https.//xyz.celonis.cloud/package-manager/ui/studio/ui/assets/xxxyyy-11-123) and an APP redirect URL (https://app.smartsheet.com/b/autorize?form.....) and every other mixture of URLs but nothing seems to work out. I have also reviewed various Celonis / Smartsheet Docs but found no answer until now.
Thanks in advance
abhishek.chatu14
Can you paste the full error here, generally the redirect URL you may need to use is mentioned in the error....
abhishek.chatu14
How you done the following ?
Register Your App Using Developer Tools
  1. Log in to Smartsheet with your developer account.
  2. Click the "Account" button in the upper-right corner of your Smartsheet screen, and then click "Developer Tools".
  3. In the "Create New App" form, provide the following information:
  • Name: the name the user sees to identify your app
    • Description: a brief description intended for the user
    • URL: the URL to launch your app, or the landing page if not a web app
    • Contact/support: support information for the user
    • Redirect URL: also known as a callback URL. The URL within your application that will receive the OAuth 2.0 credentials After you click "Save", Smartsheet assigns a client Id and secret to your app. Make a note of these Ids for the next steps; however, you can always look them up again in "Developer Tools".
So the APP-URL would be the celonis cloud URL and the redirect URL the one mentioned in my previous answer?
Forum|alt.badge.img+27
That's indeed what I would think. Any success in the mean time?
Yes, it were some small Syntax errors. Celonis and Smartsheet demand certain Syntax-format for the connection between the Smartsheet Developer Settings and the Action Flow.
