How to color code/group activities in Process Explorer used in Studio/Views
  • Nov 22, 2023 2:14 PM UTC
  • 110 views
stephan.herma12
Level 2
previously in process analytics I could manually group activities in the process explorer and designate a unique color.
Is there a similiar function in Views (except of using different eventlogs which wouldnt make sense in my case) ? The "customs" option in the knowledge modell doesnt seem to be working with the process explorer.
Thanks for your feedback
kind regards
Stephan
abhishek.chatu14
The short answer is you cannot do the same in Process Explorer currently, the only options that I have seen this working is with Multiple Event Logs or Multi-object Process Explorer
stephan.herma12
Level 2
Thank you - that’s what I thought :(
