How to change activities name while process/variant explorer for task mining activities in views section?
  • Aug 1, 2023 1:52 PM UTC
  • 169 views
sanati.dines
Level 3
Forum|alt.badge.img+2
 I have created a Activity table. in that I required to change Existing activities name .I change in transformations but it was not reflected to process explorer. for views and analysis . how to change it ?
abhishek.chatu14
DId you load the data model ?
I may be missing something here can you help me understand where are you making this change in the task mining tables ?
sanati.dines
Level 3
  • Level 3
  • Aug 2, 2023 6:39 AM UTC
snip1by mistakenly put deu misspell in due date activity.
but I changed in data job transformations like this.it display transformation name only but it was not reflect in process explorer.snp2Data model also load successfully. but it was not reflect.?
snip3
biswajit.jena12
Level 5
Forum|alt.badge.img+10
snip3
Inside the script for due date , change the spelling to "Due date" as "activity_en". then run the scripts all over again & oad the model again.
sanati.dines
Level 3
  • Level 3
  • Aug 4, 2023 12:28 PM UTC
snip3
@biswajit.jena12
Am already changed the script and also loaded model still it was not change .I am unable to find out what I am missed?snip4
