How to change activities name while creating process/variant explorer for task mining activities.
  • Sep 13, 2021 7:56 AM UTC
  • 116 views
I am using Celonis Task Mining and I was trying to create a process/variant explorer tab to show task mining activities as a process map. Here I had used column "ActiveWindow" from TM_Activities table. I was trying to get a more informative name for the task mining activities to make it more presentable and easily readable.
Below are the things I tried and how they did no work:
  1. Updated the values from the active window name in the table, but they were not reflected in the process/variant explorer even after a refresh or reload, or starting a new analysis
  2. Added a column to enter activity names manually, column was added in the table, but the same did not reflect when I tried to select different column dimensions in the process/variant explorer.
  3. I tried to use annotated activity column (comments) from user_interaction_event_log table. Even after selecting it as activity table, the process explorer would give error as not selected as activity table or the map created would be of rhombus shape not displating the correct flow.
So if anyone has worked on the task mining and updated the activites name used for process/variant explorer. Please guide on the same.
Forum|alt.badge.img+28
Hi @ashish.petka,
What you can do to change it in the process or variant explorer, is to use the 'Custom Dimension' field of the component, and enter the REMAP_VALUES function:
REMAP_VALUES ( "_CEL_P2P_ACTIVITIES"."ACTIVITY_EN" , [ '<Old Name>' , '<New Name>' ])
You should replace the values with the table.column that you want to change, and both the old and the new names.
This should solve your problem, but be aware that it will only work for the selected component (i.e. if you have multiple, please repeat this step)
Good luck!
Regards,
