How to calculate the % for a specific selection?
  • Feb 23, 2022 9:46 AM UTC
  • 41 views
I am currently using this code: SUM("Sheet1"."Column1".'1' / SUM("Sheet1"."Column1")
and I am essentially trying to find out how many 1s, 2s, and '-' there are, in the form of a percentage.
I tried doing "Sheet1"."Column1".'1' so specific which value I am trying to calculate but I don;t think the code is correct?
Thanks,
Terence
Forum|alt.badge.img+13
  • Level 7
  • Feb 23, 2022 7:46 PM UTC
Try using
COUNT(CASE WHEN "Sheet1"."Column1" = '1' THEN 1 ELSE NULL END)/COUNT("Sheet1"."Column1") - this will calculate the % of '1's in the full population
