How to calculate Process conformance by each case key for on premise 4.6 setup
  • Jan 24, 2022 1:25 PM UTC
  • 66 views
We want to calculate process conformance as a KPI in the OLAP table for each company codes, markets etc as dimensions. Two years back Celonis team showed us that this can be done by opening process conformance analysis -> press F12 and then scan the browser logs for certain keywords and use some part of the logs into the OLPA table KPI editor.
However, I dont recall all the steps but would like to understand if someone can share these steps again that would be really helpful.
We have 4.6 on premise setup.
PS: Tried using CONFORMANE PQL syntax but this proved way more difficult given complex process model design.
Regards,
Amogh
Hi Amogh, Many thanks for contacting us. In order to be able to assist you further, we need to engage the relevant team, hence we would suggest raising a case or sending an email to servicedesk@celonis.com. Many thanks for your patience. Best regards,
