How to calculate median for this ask. Requirement: Casetable count for a specific activity per document type?
  • Aug 5, 2022 4:00 PM UTC
  • 6 replies
  • 124 views
Hello, not sure to understand your request but do you want like an OLAP Table with :
  • Document Type as DIMENSION
  • Count table as KPI
  • Specific activity as Filter or dropdown button ?
Here, I don't see where Median is required
  • Aug 9, 2022 10:41 AM UTC
Thanks for your response.
I need this in a Number component.
It has to be like Median(count(casetable, activity table, activity = 'name') /
count(distinct (table.column)))
For this I'm getting aggregation error.
Does it works when you do only : Median(count(casetable, activity table, activity = 'name') ?
According to me, we can't accumulate aggregation expression, Celonis says ("Aggregate expressions cannot be nested inside aggregate expressions") so the solution could be PU fonction
Best regards
  • Aug 9, 2022 4:44 PM UTC
Hi @francois.court
Yes, I tried with PU function too.
Can you help me with example code to achieve the median with a pu function.
I need to consider 3 different tables inorder to achieve the correct result.
I would like to but I am afraid I can't, sorry :
"Median(count(casetable, activity table, activity = 'name')"
would be : Median (PU_COUNT(casetable, activity_table, activity = 'name')
But, in PU function we need two tables so the division part can't work as it stands
imageSo I think the easiest way is an OLAP Table as in my first message
Hope you will find out
Best regards
  • Aug 12, 2022 4:24 AM UTC
No worries, Thank you for the inputs
