How to calculate FTE
  • Jun 13, 2022 4:33 AM UTC
  • 150 views
I wanted to calculate all documents processed by any user per day.
Can anyone help with formula or explanation how it can be done
  • Jun 13, 2022 5:49 AM UTC
Hi Preethi ,
The Logic Could be:
  • Take count of documents processed for a particular period - A
  • Take Count of Distinct related users associated with Documents processed for the same period - B
  • Take the count of Days ( It could be weekdays only or Inclusive of Weekends Too depending upon your actual business Needs) for the same period -C
Formula is: (A/C) This gives you the number of docs processed per day .. Then Divide the same with B to get the number of documents processed by Any user/day
No of Documents processed by Any user per day = ((A/C)/(B))
Hope this helps..
Please mark my response as best - if this is helpful to you.
Regards
Ayan
  • Jun 14, 2022 10:01 AM UTC
Hi Preethi ,
The Logic Could be:
Hope this helps..
Regards
Ayan
Any example code. If possible?
