How to calculate automation rate in PQL?
  • Mar 22, 2023 4:53 PM UTC
  • 238 views
Best answer by andré.tafur
Usually you need to include a User Type column in your Activity Table to distinguish if the activity was executed by a human user or if it was executed by automations, with this requirement you could use the following PQL:
AVG(CASE WHEN ISNULL("ACTIVITY_TABLE"."USER_TYPE") = 1 THEN NULL
WHEN "ACTIVITY_TABLE"."USER_TYPE" IN(<%=automatic_users%>) THEN 1.0 ELSE 0.0 END)
Hope it helps.
andré.tafur
Level 8
Forum|alt.badge.img+19
  • Level 8
  • Answer
  • Mar 22, 2023 7:39 PM UTC
Hope it helps.
  • Mar 23, 2023 11:59 AM UTC
Hope it helps.
Thank you:)
