How to apply conditional formatting in an OLAP table(Analysis) using icon sets?
  • May 4, 2022 4:31 PM UTC
  • 155 views
leonor.doris.rodri
Level 3
Is there a way to use conditional formatting with icon sets, similar to what it's done in Excel? I need to replicate the RR column of the table Status X Area (last column of the picture).
imageThanks
LDRH
  • May 10, 2022 2:06 PM UTC
Hi @leonor.doris.rodri ,
As far as i know it's not possible to use icon sets in analysis, but you can if you build your table in views instead.
burim.hoxha
  • Celonaut
  • Nov 9, 2022 9:40 AM UTC
Hi Lenor,
Conditional formatting using icons isn’t possible currently. You can only do conditional formatting using colors:
a1Thanks and best regards,
