How to add days to a date column in vertica sql?
  • Jan 25, 2023 2:54 PM UTC
  • 238 views
I want to calculate start and end week of a particular date where week start date is Monday and end is Sunday
I’ve tried using ADD_DAYS & DATEADD which is in supported vertica sql functions but getting error that it requires permission
Best answer by Anonymous
Try TIMESTAMPADD
https://www.vertica.com/docs/9.3.x/HTML/Content/Authoring/SQLReferenceManual/Functions/Date-Time/TIMESTAMPADD.htm
  • Answer
  • Jan 25, 2023 3:09 PM UTC
Forum|alt.badge.img+28
Hi @Preethi P,
Strange that ADD_DAYS & DATEADD don't work, since they should be supported (see Supported Vertica functions (celonis.com)). Also, the ADD_MONTHS works, which is in the same area.
If this error persists, you could create a support ticket to Celonis.
  • Jan 27, 2023 5:33 PM UTC
  • Jan 27, 2023 5:34 PM UTC
Hi @Preethi P,
@janpeter.van.d yes, I’ve checked as they listed as supported functions.
Yes, I created a support ticket
