How to add concatenated column in benchmarking dropdown and filter that column with KPI's and process explorer
  • Jul 5, 2023 10:15 AM UTC
  • 15 replies
  • 189 views
  • Jul 5, 2023 10:47 AM UTC
Hi Varun,
are you using one of the Celonis starter kits?
  • Jul 5, 2023 10:52 AM UTC
No, i am creating knowledge model from scratch, it is not starter kit
  • Jul 5, 2023 11:00 AM UTC
Ok, but how far have you come? Were you able to create the dropdown and update variables for filtering?
  • Jul 5, 2023 11:16 AM UTC
yes, i have created an attribute in KM with concatenated column and configured that in dropdown but i am not able to use that for filtering as it says column not found
kailash.potha12
Hi Varun,
You can try to use the concatenated formula directly in filter statement.
Example:
(dimension_benchmark ==="plant" && "AUFK.WERKS ||' - '|| AUFK.DWERK_TEXT")} = '${benchmark_1})
  • Jul 5, 2023 11:55 AM UTC
For dropdown columns how should i configure concatenated columns?
Now i have created a new attribute which is not recognized by PQL,it says missing column in that table
kailash.potha12
Try to use Tablename.AttributeID. if are you having same ID in different tables sometimes it will give an error.
  • Jul 5, 2023 1:08 PM UTC
can you guide me how to add concatenated column in custom object for drop down.
in the below code instead of EKPO.BUKRS i need EKPO.BUKRS concatenated with EKPO.BUKRS_TEXT
customObjects:
  - id: dimension
    displayName: dimension
    customAttributes:
      columns:
        - id: EKPO.BUKRS
          displayName: company code
        - id: WERKS
          displayname: Plant
        - id: MATKL
          displayname: Material
kailash.potha12
customObjects:
  - id: dimension
    customAttributes:
      columns:
        - id: EKPO.BUKRS
        - id: WERKS
          displayname: Plant
        - id: MATKL
  1. Create an attribute in EKPO with concatenation of this field (Ex : CompanyCode_CC)
  2. Use it in Custom objects CompanyCode_CC
  3. Process explorer filter:
${(dimension_benchmark ==="CompanyCode_CC" && "EKPO.BUKRS ||' - '|| EKPO.BUKRS_TEXT")} = '${benchmark_1})
dimension_benchmark : Variable holding benchmark dimension
benchmark_1 : Variable holding benchmark value
  • Jul 5, 2023 4:25 PM UTC
I am facing below error.
Process Explorer [id:process-explorer-49fa3908-9a29-4c19-aa05-499de7342f33]: Invalid PQL query. Syntax error near [false] after reading [] at line 1. Please refer to PQL documentation for available syntax., Syntax error near [false] after reading [] at line 1. Please refer to PQL documentation for available syntax. Please review your PQL statements in the Knowledge Model and in the View YAML filters.
type: process-explorer
settings:
  eventLogs:
    - eventLog: EL_CEL_P2P_ACTIVITIES__ACTIVITY_EN
      order: 100
  transitions: false
  graphControls: panel
filters:
  - pql: ${(dimension_benchmark ==="companycode_cc" && "EKPO.BUKRS ||' - '||
knowledgeModelKey: ptp-km
  • Jul 6, 2023 3:22 AM UTC
Hi Varun,
One solution is to add a new column to EKPO in Data Transformation. This worked for me, because then I was able to add just one column to the filter expression in the YAML file.
For Example: Name this column "CompanyCode_CC". Then the filter expression should look like this.
${(dimension_benchmark ==="CompanyCode_CC" && "EKPO.CompanyCode_CC")} = '${benchmark_1})
kailash.potha12
You missed 'Filter' word
- pql: FILTER ${(dimension_benchmark ==="companycode_cc" && "EKPO.BUKRS ||' - '||
   EKPO.BUKRS_TEXT")} = '${benchmark_1}'
  • Jul 6, 2023 7:39 AM UTC
Yes, i was able to resolve the error by adding FILTER.
Would you mind sharing the syntax for adding one more concatenated dimension in the filter statement.
kailash.potha12
You can add it in same way using || Operator
- pql: FILTER ${(dimension_benchmark ==="companycode_cc" && "EKPO.BUKRS ||' - '||  EKPO.BUKRS_TEXT") || (dimension_benchmark ==="companycode_cc" && "EKPO.BUKRS ||' - '||  EKPO.BUKRS_TEXT" )} = '${benchmark_1}'
  • Jul 6, 2023 1:48 PM UTC
Thank you very much. It is working now😊
