How many characters are supported for naming convention for any object in Studio?For example if I am naming a ID for a KPI, how long can I keep the name? Do we have a constraint in that?
  • Feb 6, 2023 10:18 AM UTC
  • 137 views
praveen.ojha12
Level 6
How many characters are supported for naming convention for any object in Studio? For example if I am naming a ID for a KPI, how long can I keep the name? Do we have a constraint in that?
abhishek.chatu14
The limit is 40 characters for naming a ID for a KPI, however the same may differ from case to case i.e. if I was creating a View it would save more than 40 characters but does start throwing an error at some point with respect to not being able to create the view
praveen.ojha12
Level 6
Hello @Abhishek Chaturvedi ,
Thanks for replying, but is it your experience or can we see such description anywhere?
As based on the same I can convey to my clients.
abhishek.chatu14
You should see an error message when trying to fill the field with more than 40 characters, kindly find attached screenshots
