How long it takes APC Consumption to get updated?
  • Aug 31, 2022 7:21 AM UTC
  • 131 views
I use free version and I crossed APC limit and then I deleted everything it's been already 4 days the APC consumption is not updated, the last APC consumption is updated days ago . How much I have to wait or is there any way that I can reset it manually ?
mukesh.gupta11
Level 7
Forum|alt.badge.img+15
Hi Moeen,
Hope you have deleted the tables from data pool to free up the APC space . if issue is still persisting Please reach out to the Celonis Services Desk(Celonis Support <servicedesk@celonis.com>), they will resolve the APC consumption issue from backend.
  • Sep 1, 2022 9:36 AM UTC
Typically every 24 hours the APC updates
  • Sep 1, 2022 9:46 AM UTC
its last updated on 27 Aug, I check every it showing same , no APC updated
patrick.groth12
Level 4
We also had to get in touch with the celonis update after having cleared the whole space.
