How does rest API works to connect with Celonis
  • Sep 17, 2021 7:11 PM UTC
  • 58 views
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Sep 20, 2021 9:27 AM UTC
Hi @bishal.agarw11 ,
Did you search the help documents (available for instance once logged in to the Celonis Free Edition).
If not, could you provide a bit more detail as to which REST API you're referring to specifically?
