How do you push a DataFrame to your DataPool in PyCelonis 2.7.0)
  • Mar 14, 2024 1:46 PM UTC
  • 256 views
miguel.ferna11
Level 4
Forum|alt.badge.img+18
This is the code I'm trying to execute:
celonis = get_celonis()
data_pool_name = "dataPool"
data_pool = celonis.data_integration.get_data_pools().find(data_pool_name)
column_config = [
  ColumnTransport(column_type = ColumnType.STRING, field_length = 10000)
data_pool_table = data_pool.create_table(df = dfResult, table_name = "tableName", drop_if_exists = True, column_config = column_config)
This is the error code:
Response: Server error '500 Internal Server Error'
The table "tableName" already exists with a defined column named "_COL" inside the DataPool, which has a specific DataModel with just that table. The pandas DataFrame dfResult is a 1x1 table with a string inside.
Does that error code mean only the Celonis server is to blame?
mallik.koruk11
Level 6
Forum|alt.badge.img+10
Try upsert_table instead of creating, there might be a table with same name already exists in the Data Pool.
data_pool.upsert_table(df_or_path=dataframe, table_name=table_name, primary_keys=primary_keys)
deeksha.r12
Level 8
Forum|alt.badge.img+3
  • Level 8
  • Mar 21, 2024 3:21 AM UTC
Hi @miguel.ferna11
If you want the output dataframe to be created as a new table, you can try this:
data_pool = celonis.data_integration.get_data_pool('DATA POOL ID')
data_pool
data_pool.create_table(df=output_df, table_name="NEW TABLE NAME", drop_if_exists=True)
