How do you divide each element of a column that has been counted in an aggregated manner (PU_COUNT) with the sum of the same column?
  • Aug 6, 2021 12:51 PM UTC
  • 154 views
Forum|alt.badge.img+7
I tried something along the line of
( PU_COUNT(target_table, source_table.column))/SUM(PU_COUNT(target_table, source_table.column))
But I got an error saying:
"The aggregation function SUM cannot be used together with a dimension function input. Please check that there are no aggregations and dimensions used together as function inputs"
joos.buijs
Forum|alt.badge.img+9
  • Level 10
  • Aug 6, 2021 2:20 PM UTC
Hi @mohamed.ruzli.moham ,
I'm not fully understanding what you're trying to achieve.
I'm guessing you either want to:
  1. remove the 'PU_COUNT' in the second half of your PQL formula
  2. Try to add 'AVG()' to the first part, but I doubt whether that will work, and whether it is what you're looking for.
If both my suggestions don't acchieve what you want, could you try to clarify what your want to divide with what exactly?
Hi @joos.buijs ,
To further clarify I have done a PU_COUNT certain elements to group them properly
No I want to find a way I can get a percentage amount for it based on the category that I aggregated it for
So I need to grab each element from the aggregated column and divide it by the total of that column and multiply by a 100 to get a percentage value
Hopefully this makes sense
Forum|alt.badge.img+27
Hi @joos.buijs ,
Based on this, would changing the second 'PU_COUNT' in 'PU_SUM' be a solution?
