How do you compare Process Mining Software and which criteria is useful?
  • Apr 2, 2022 7:45 AM UTC
  • 64 views
Hello Guys,
I'm currently writing a seminar paper about the Process Mining software from Celonis. The task is to first define criteria that can be used to evaluate process mining tools. The PM software from Celonis is then to be evaluated using the criteria shown.
Can you help me with that? Which criteria should I choose?
Thanks very much.
Tobi
Hi Tobi,
Hope you're doing well. If this is still relevant, could you please reach to  academic.alliance@celonis.com ? They'll be able to help you out.
Kind Regards,
Mentor
