How do I combine to CSV files which has the same headers headers but data from two different dates in Celonis?
  • Nov 18, 2021 12:23 PM UTC
  • 67 views
I have two CSV files with the same headers. The only difference between the files is that it contains data from two different dates. For example one csv file has data for today's sales. The other CSV file has yesterday's sales. In Celonis I have already uploaded the CSV for yesterday's sales. How do I now upload and combine the CSV for today's sales, into the data for yesterday's sales which is already in Celonis.
Hi @jed.nkans ,
I think combining the two tables can be achieved by using transformation job in the data pool.
If there is a date column in your files, then I would suggest:
1- DROP TABLE IF EXISTS "SALES";
2- CREATE TABLE "SALES" AS (
    SELECT
    FROM "yestrday.CSV"
3- INSERT INTO "SALES"
    SELECT
    FROM "today.CSV"
In the case that the csv files does not include a Date Column you can create a column date:
    SELECT
        * , '17/11/2021' as MY_DATE
    FROM "yestrday.CSV"
    SELECT
        *  , '18/11/2021' as MY_DATE
    FROM "today.CSV"
After this, you can import the SALES table into the data model and not directly the csv file and should work,
Hope it helps
Javier
Hi @jed.nkans ,
    SELECT
    FROM "yestrday.CSV"
    SELECT
    FROM "today.CSV"
    SELECT
    FROM "yestrday.CSV"
    SELECT
    FROM "today.CSV"
Hope it helps
Javier
Hi Jed,
The suggestions from Javier should work indeed, and another idea could be to use the UNION or UNION ALL function to create the unified table directly.
