How do I activate/deactivate Dark Mode for SQL windows?
  • Aug 17, 2023 2:47 PM UTC
  • 5 replies
  • 296 views
manuel.wetze
Forum|alt.badge.img+9
In the Windows under Data Integration where I write SQL Code for Transformations I sometimes have dark mode (white font on black background) and sometimes the other way around. It seems this changed from time to time and from environment to environment.
Where can I set this? How is this being influenced? Obviously being a developer I want dark mode all the time 😁
Best answer by mallik.koruk11
Hi Everyone,
Using the white setting continuously can cause discomfort in the eyes. The instructions to enable and disable Dark Mode in the SQL window are listed below.
Actually, you can enable the "dark Mode" at any time on the workbench by right-clicking and selecting Command Palette > Toggle high contrast theme; but it is not durable, and as soon as you depart the transformation, it returns to standard.
Hope this will help you :)
  • Aug 18, 2023 6:15 AM UTC
I am really interested too.... anybody who finds out, please share....
  • Dec 4, 2023 10:56 AM UTC
yes, searching as well, please share :) !!
herique.sarme
Level 4
Has anyone figured it out already? My eyes hurt with the white mode on all the time 😅
mallik.koruk11
Level 6
Forum|alt.badge.img+10
Hi Everyone,
manuel.wetze
  • Level 10
  • Feb 20, 2024 8:15 AM UTC
thanks for the solution :) weird that it changes from time to time, but now I am able to control it
