How do clients use Celonis in the Coupa environment?
  • Feb 20, 2024 4:36 AM UTC
  • 137 views
Sverre Klein
Forum|alt.badge.img+13
Hi @mpho.mathe,
Could you specify what you mean by "use Celonis in the Coupa environment?" What do you specifically want to know? 😊
Sverre Klein
  • Feb 21, 2024 8:55 AM UTC
Hi Svere,
I would like to know how Celonis can be used to complement what Coupa offers.
Sverre Klein
Hi @mpho.mathe,
I see, thanks for clarifying. I think this can be best explained by providing an example.
Let's say you are from procurement, and you want to improve your sourcing / contract management process.
You can use Coupa to:
  • Create sourcing events and contracts
  • Collaborate with suppliers
  • How much you are spending against your contracts.
Coupa is not really enough however how efficient your sourcing / contract management process is, or how you could improve it.
Therefore, you can use Celonis to:
  • See which suppliers are not complying to your contract terms.
  • Identify which suppliers are causing your process to deviate from the happy path.
You can also automate your process in Celonis to Coupa:
  • Automatically send reminders and escalations if something goes wrong in your process
  • Updating or adding approvers to requisitions in your Coupa account.
  • Creating and submitting expense reports based on your travel and credit card data.
  • Tracking and optimizing your inventory levels and usage.
  • Consolidating and automating your payments across currencies and accounts.
Hopefully this helps you!
Sverre Klein
Sverre Klein
Hi @mpho.mathe,
I hope you got the answer you were looking for?
Sverre Klein
