How can we extract execution logs such as transformation script logs from front end.
  • Sep 8, 2021 6:07 AM UTC
  • 65 views
Forum|alt.badge.img+7
  • Level 0
  • Oct 26, 2021 3:56 PM UTC
Hey Nikihil,
This is a new feature that should be available either now or fairly soon that allows you to monitor your data pool event logs and build analyses off that data.
You can access the detail in the help area with the below URL ending. Just put your environemnt where the X's are.
XXXXXXXXXXXXXXXXXXX/help/display/CIBC/Custom+Data+Pipeline+Monitoring
-Cody
