How can we create second Process Explorer in my Analysis?
  • Feb 16, 2023 11:48 AM UTC
  • 56 views
Forum|alt.badge.img+28
Hi @sachin.agarw,
If you want to have multiple Process Explorers, the best thing to do is not adding the process explorer as Sheet, but as a component in a sheet.
Process Explorer ComponentWhen doing this, in the component settings you can specify the range (or select a certain Activity Table) which you woul like to visualize.
Select Scope of Process Explorer
