how can we create benchmarking using new views
  • May 21, 2024 3:55 PM UTC
  • 166 views
harini.p26
Level 3
I am able to create benchmarking using legacy views but when i try using the same method in updated views i am getting errors.
Carolin Ullrich
Hello Harini, could you describe the steps you tried and which errors you get?
harini.p26
Level 3
  • Level 3
  • May 23, 2024 3:14 PM UTC
Hi
I am trying to create an benchmarking by using enhanced views but when i create the view variables and object variables, when i try to assign them to a input dropdown they are working fine but when i assign the same view variable to the process explorer by using filter it is working fine.
But when i try to assign same view variable to KPI list or KPI card by using the YAML editor, i am seeing that the view variables and object variables are disappearing. Please help me out in this
