How can we connect Celonis to SAP BW/4HANA
  • Aug 19, 2021 6:29 AM UTC
  • 169 views
Please mention the way to connect. Is there a connector available ? Can we create a custom connector?
  • Level 6
  • Aug 19, 2021 1:36 PM UTC
Dear, @pawan.dihiy
You can find connectors for most major systems, like SAP 4Hana, in the App store. If needed, you could also create your own connector (Event Collection->System Administration->Extractor Builder).
As for the connection process, it's too complex to explain here. But you can take an e-leraning course in Celonis Academy which explains that in detail (and it has some exercices involving precisely a SAP system): Data Engineer trainning track.
I hope this helps...
  • Level 1
  • Aug 20, 2021 5:00 AM UTC
Hi @1460047871
Appreciate the response!
However , I am looking for information specific to SAP Business Warehouse. If you have any knowledge on : Whether it is possible to connect SAP Business Warehouse(Its a BI Tool) to Celonis. ? Please let me know . I would be very thankful.
