How can I use Union on PQL to combine data from two tables?
  • Aug 24, 2021 4:55 PM UTC
  • 91 views
I want to combine data from two tables on the frontend using PQL query. Not sure how to do it.
Hello.
PQL Performs implicit joins when using data from several tables.
check this to understand more about joins: https://help.celonis.cloud/help/display/CIBC/Join+functionality
Domain_Table can also help you. this creates temporary tables from various columns, and you can use it inside PU_FUNCTIONS.
https://help.celonis.cloud/help/display/CIBC/DOMAIN_TABLE
Thank you.
D
  • Aug 27, 2021 9:48 AM UTC
Hello.
Thank you.
D
Thanks
