How can i tell if my EMS connection has microsoft features enabled?
  • Aug 25, 2025 3:59 PM UTC
  • 73 views
mtucker10
Level 1
I’m trying to create a data connection between Celonis into Power BI. When I put the hyperlink into the ‘get data’ prompt, the navigator pane is blank (ie shows no data available).
I’m curious if I have the microsoft connection enabled. How can I check this?
Important to note - I do not have analyst rights in Celonis hence why I’m attempting to import data into Power BI.
