How can I show KPIs specific for a period and Same KPI from the beginning till now , side by side in same sheet
  • Apr 14, 2022 7:21 AM UTC
  • 103 views
I am building an analysis.
I have a period Filter :( YYYY-MM ) format.
While I choose a Period I get to see KPIs specific to that period , but the requirement is , even if I select a specific period, same KPI should show me 2 different values , 1. For the specific period choses 2. KPI value since beginning till date , it should ignore the Period filter value chosen. These two Same KPIs to be placed side by side on the same screen.
  • Can we do this ? If yes, then How ?
Regards
Ayan
Best answer by .14600110018
Hi @1460069622 ,
Click on the KPI you don't want to be filtered on the date, go to the bottom of the settings and check the box "Component is not filtered with selection". Hope this helps!
  • Level 11
  • Answer
  • Apr 14, 2022 7:56 AM UTC
Hi @1460069622 ,
  • Level 8
  • Apr 14, 2022 8:32 AM UTC
Hi Lorenco - Great , Thanks , it works exactly the way I want .. Thanks again - Ayan
  • Level 8
  • Apr 14, 2022 8:52 AM UTC
Hi Lorenco ,
I already marked your response as "Best".
Regards
Ayan
