How can i send the csv through action flow while using the smart sensor?
  • Aug 23, 2024 6:50 PM UTC
  • 102 views
nitish.kumar23
Level 1
Forum|alt.badge.img+7
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
From where that CSV file will come from? You can always try to flatten it into very long string > send over and recreate in a form of file if needed (example: csv attached to the email).
Mateusz Dudek
