How can I get JDBC_Extractor_Package.zip?
  • Jan 24, 2022 12:37 PM UTC
  • 7 replies
  • 149 views
I want download 2022-01-13-JDBC_Extractor_Package.zip to verify connection with onpremised system.
I tried download this URL, but I get only downlaod.html.
https://academic-*****.eu-2.celonis.cloud/help/display/CIBC/Downloads+and+Version+History
The only thing I can think of is that downloading the extractor is restricted for academic purposes. Maybe the help desk can help you with this one!
Forum|alt.badge.img+28
Hi @hideyuki.nomur,
If you open the download.html in your browser, do you see then a download link? Celonis is sometimes using this intermediate step.
  • Jan 25, 2022 1:37 AM UTC
Hi @janpeter.van.d
Thank you for your comment.
I can't see any download link...
only download logo.
note: my browser is Chrome 97.0.4692.71. and OS Windows 10
I can't Download Windows & Linux JDBC Extractor Package.( 2022-01-13-JDBC_Extractor_Package.zip)
but, I can download other Dockerized JDBC Extractor Package in same download page.
why??
  • Jan 25, 2022 8:26 AM UTC
Try to use: <your_celonis_link>/help/download/attachments/10944543/2022-01-13-JDBC_Extractor_Package.zip?version=1&modificationDate=1642161266000&api=v2&download=true
It should be direct link to 2022-01-13-JDBC_Extractor_Package.zip file, let me know if that worked.
On my side downloading was working fine with Firefox 96.0.2 (64 bits) and Chrome Version 97.0.4692.99 (Official Build) (64-bit) on Win10.
Mateusz Dudek
  • Jan 25, 2022 10:18 AM UTC
Mateusz Dudek
Hi
I tried open commented URL.
but Browser redirect to <my_celonis_link>/help/error/#/forbidden-page
It's 403 Access forbidden page...
  • Jan 26, 2022 2:38 AM UTC
OK!
I will try send mail this case to service desk.
Thank you!
  • Feb 16, 2022 5:58 PM UTC
Hello there - I had the similar issue - I would suggest downloading and then copying or "sending" on the client VM or network.
Hope this helps.
