How can I delete a Data pool?
  • Sep 5, 2023 10:52 AM UTC
  • 89 views
parvathi.choud
Level 7
dennis.pflug
click on Data -> Data Integration -> See a list of all Data Pools.
Press on the three dots on the right side and select "Delete"
You are asked if you really want to delete the pool? And you need to confirm by entering the Data Pool name into the free text field and then press "Delete".
BR
Dennis
