How Can i connect the purchase side and sales side in a process explorer which will display the P2P-AP process in one side and O2C-AR process in one side AND the explorer should also display the connection between the 2 process flow??
  • Dec 10, 2022 11:14 AM UTC
  • 5 replies
  • 124 views
I am working on an intercompany transaction where one subsidiary of the parent in buying material from a vendor which is a subsidiary of the same parent. Hence O2C-AR of the buyer should be synced with the P2P-AP of the vendor.
  • Dec 12, 2022 8:38 AM UTC
Buf, I am afraid that you will need to wait for PRocess Sphere ... :D
That being said, you can try with Process Explorer in Views.
Something like this, I guess:
BTW you can define the "contact points" between processes.
Check here: https://docs.celonis.com/en/process-explorer.html
Also you can try to model it with Network Explorer: https://docs.celonis.com/en/network-explorer-and-signal-link-explorer.html
HTH
  • Dec 12, 2022 9:28 AM UTC
HTH
Thanks a lot for the info @Guillermo Gost . I will try to implement it
  • Dec 12, 2022 11:45 AM UTC
does anyone know when this is finally coming?
  • Dec 12, 2022 12:03 PM UTC
Do you mean "Process Sphere", yes?
For what I understood, it is still in closed beta (in fact, my feeling is that is more an "advanced alfa" stage)
No release date AFAIK
swapnil.karad12
Level 1
​@guillermo.gost12
​@sayan.chakr12
can you guide me how its done
