How can I concatenate all values of one column into one string in SQL without using STRING_AGG()?
  • Sep 13, 2021 1:38 PM UTC
  • 149 views
For example:
column_a
"one"
"two"
"three"
Then: STRING_AGG("column_a", ',') => "one,two,three"
STRING_AGG is not available as an error message tells me. How can I perform this action then?
(I am working on a Transformation in a Data Job.)
(CONCAT() concatenates across columns, but I want to concatenate across rows.)
Forum|alt.badge.img+27
Hi @1460047096,
Maybe this thread will solve your problem. Unfortunately it is a work-around which isn't perfect. Hope it helps!
VERTICA LISTAGG function (celopeers.com)
  • Level 2
  • Sep 15, 2021 3:30 PM UTC
Hi @janpeter.van.d ,
Thanks for your reply!
One question about the approach that you suggest in the other thread:
Is it correct that I would need to pre-define the number of rows that can be concatenated, by the number of joins I implement? If so, I cannot use the approach, because I don't know the number of rows to be concatenated in advance, unfortunately.
Best wishes,
Bennet
@1460047096,
That's exactly the limitation of this approach. If that doesn't work for you, I'm out of options unfortunately.
  • Level 2
  • Sep 16, 2021 9:39 AM UTC
Not for this use-case unfortunately. Nevertheless, thanks a lot for your elaborate approach!
