How can I avoid null values from a 2 columns that I am trying to find the difference for?
  • Aug 18, 2021 3:46 PM UTC
  • 64 views
Forum|alt.badge.img+7
I have 2 columns in which I am looking to find the difference for. Since some values of each column contain a null they are not reflected accurately
for example
Column 1 Column2 Diff
2 1 1
4 NULL NULL (should be 4)
NULL 5 NULL (should be -5)
I have the formulas associated with getting values in Column 1 and Column 2 within saved formulas as "KPI(.......)".
My initial idea was to substitute NULL as 0, but when I surround KPI(...) with a CASE WHEN it fails saying that CASE is not supported with INT or STRING
Any ideas?
Using the above resource I was able to use the COALESCE function to change the NULL values to 0
